We are having problems with my replica also . We have been trying to figure out a way to mount it . It does seem to fit the lines if you push hard enough on both side of the wing . Still seems a lil shy of fitting all the way to the edge of the hatch on both sides . We are going to try to mount studs in the wing where the nuts are (were) before the fell out. I wouldnt recc. anyone else buy this wing unless they are ready for Much work installing it . Non of the factory holes line up so that you can even begin to mount it . Then after you drill your holes you relize the nuts pull right out of the wing . Rough finish is very rough and needs alot of work to make look right before you could even come close to painting it . I cant even get a reply from Jose in over 3 weeks now . My car is on hold again from being painted till we figure this out . I may end up going wingless which I really dont want to do but dont want to drive it home in the snow either :(
